2003 2WD Rear End / Gear advice
I just finished the 2 piece driveshaft rebuild on my 2003 ECSB 5.3L 2WD and I have the transmission scheduled for a rebuild with upgrades on the 19th of this month.
I have 320,000 miles on the drivetrain (except the motor and driveshaft now) so its due.
Currently, the rear end is an open 3.42. It's never been touched apart from fluid changes.
The old hot rodder in me wants to swap it over to some sort of limited slip rear end and a 4.11 gear and do the whole thing including axle bearings, seals and all. I'm also thinking of ONLY doing the ring and pinion with axle seals if I don't find any benefits to switching to a limited slip.
I'm not really a fan of the G80 but I wouldn't rule out a total rear end swap if the gear ratio and price were right. But I would still likely rebuild it because I want it to last another 300K miles.
I'm not a street racer, off road-er and I NEVER tow anything. As it is now, I can smoke the daylights out of the right rear at will. Additionally, I have a 50 mile round trip to work each day, mostly highway. Mileage isn't a deal breaker, but I don't think I want to go much more than 4.11 and not sure I'd notice the difference with a 3.73.
I'd just like a lot more seat of the pants feel off the line from time to time.
That being said, What are some of the best options out there? I've looked at Detroit Truetrac, Yukon, Auburn etc... When checking hard parts for my rear end (minus axles) with a limited slip carrier, ring and pinion set and bearings it is going to be close to $1000. Then labor for someone who knows what they're doing. I'm ok with that, as long as I only have to do it once. Doing the ring and pinion only would likely be 1/3 of that for everything.
I just need to decide what I want to do. Any input, links, information or experience would be greatly appreciated.
BTT
Thoughts?
http://www.ronsmachiningservice.net/gear-posi-packages/chevy-10-bolt-8-6/1999-2008-model-years/1999-2008-gm-8-6-truetrac-posi-4-11-usa-gear-package/
Application: 1999-2008 GM 8.6" Chevy 10 bolt rearend (1/2 ton pickup)
Axle Spline: 30
Package Includes
1- GM 8.5" 4.11 Ring and Pinion
1- GM 8.5" Eaton Truetrac
1- GM 8.6" Master install kit
Is there anything else needed?
Axle seals/bearings are another $60 / pair
That would be $710 plus shipping total
The lower gears would definitely give you more umph. I spend a significant amount on the highway and the 3.73's are perfect for what I do, but if you aren't concerned by mileage then I'd go for it (I'm not either most of the time). I'm planning on a TruTrac as well eventually.
The only other thing is getting the pickup recalibrated for the new gears.
A call to BlackBear is in order after the rear is done....
I'm thinking that will be all the hard parts required, can anyone confirm?
IMO, get a tune or something to give it more go. Put a truetrac in it to give it more grip & leave the gear ratio as is.
You get the best of both worlds that way, especially with the amount of driving you do.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 321 Guests (See full list)
