2007 LBZ 2500 duramax 4x4
Hey Guys Im new around here but wanted to get your opinions on the 2007 LBZ 2500 duramax 4x4 and some basic input on different things like if different options are better to have than others etc. I have a 2008 1/2 ton Texas edition but i had and 05 1/2 ton before that and really liked the body style better than my 08. This will be my first diesel so feel free to throw and advice my way on any basic info that i should know. I will use it to hall a 15,500 lbs RV maybe twice a year and not for any great distance. from what ive heard and read the 6.6 that comes in the turck is a good motor that everyone seems to be fairly happy with. but did hear that upgrading the injectors was a good idea as preventive maintenance. So thoughts on the truck, motor, will it be fine pulling my trailer etc? Thanks in advance.
15k is too heavy for a 3/4 ton I think... Most people add a lift pump and filtration and go on those trucks.
If you can find a nice one for under $35k go for it.
Your getting to dually territory with that weight.
ok thanks for the input and I have family that has dually's if i ever need to move my camper it will be set up and staying in one spot all the time. I want to use this truck as my daily driver and really don't want a dually as a daily driver. the trucks ive found for sale in my area that are in good condition usually have between 100k - 180k miles on them and range from $17,500 - 28,000. dose this sound about right to yall KBB has the truck in great condition listed at 22,000
Sounds about right. my 06 with 160k on it owls worth 24k clean retail. I wouldn't change injectors on the lbz they are pretty good stock. I would recommend a moderate program nothing extreme ( to avoid limp mode repeatedly) and drive it. I guarantee you will be happy, have a strong reliable truck that gets better fuel economy than your 08 1/2 ton
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
