2007 - 2012 Sierra / Silverado Diamondback Tonneau cover shortbed
I have a few items for sale that came off my 08 Silverado crew cab, short bed. I sold the truck, and I ended up removing most of the accessories from it.
For sale:
Diamondback tonneau cover. Cover has Linex on it, and it is awesome. I already ordered a new Diamondback cover for my new truck. Check out the Diamondback website. This cover truly lives up to all their promises. Good condition. No damage, and Linex still looks good. Price: $1100 plus freight shipping. I will be using the box that my new cover comes in, so it will be well packaged.
Pictures of the truck with the cover on.
https://www.dropbox.com/sh/0v9a26mv5p2msij/AADh6FY_Erkbj3V7AWa8RKmYa?dl=0
From the manucaturer:
This DiamondBack Heavy duty diamond plate aluminum truck bed cover features a modular hinge design, so that you can easily remove panels as needed. You can also fold them back. For strength and durability, the truck bed cover is constructed with stainless steel external hardware and a neoprene gasket seal. Panels can be easily installed and do not require drilling. The strong truck bed cover is capable of handling up to a 400lb. load.
Features:
Deck: 3003 alloy brite aluminum tread plate, a full .100" thick (compare to toolboxes 0.063")
All stainless external hardware
7 Aluminum Box Channel Supports
All interior hardware is zinc-plated steel
Panels are secured by four 3/8" deadbolt style locking rods directly under the bedrails of the truck
Installation Requirements: 9/16" socket; no drilling or tracks required
2007- 2012
Superior Style:
A load-bearing, aluminum diamond plate truck cover looks tough and stylish.
Unparalleled Hauling Capacity:
A 1600 lb. distributed load capacity (OR two full-size ATVs) provides numerous hauling options.
Fold back panels to open up truck bed space.
12 tie down cleats ensure easily secured cargo.
Opens Front and Back
Foldable or Removable Panels
Accessibility:
Winged panels give access to the front and rear of the truck bed.
No more crawling into the bed to retrieve cargo
Security:
Two keyed locks on the Cover make the truck bed a secure storage area.
Steel rods lock into the side rails - no drilling required.
Weather Resistance:
A full compression seal keeps your bed and your cargo dry.
Center panel gutters channel water run-off when the large panels open.
Easy Installation:
Easy self-installation clamps secure the center panel to the bed rails.
Two large panels hinge on to the center panel.
Quick release gas springs can be detached easily.
Individual panels can be detached for quick, easy installation or removal of the cover. Removing the cover takes 10 minutes and can be done by one person.
