Alternator size 2000 Silverado
jmas16
I am going to get a serpentine belt component kit. There are two offered on a popular website, one for a 105 amp alternator and the other for a 130 amp. How do I tell the difference? The truck is a totally stock 2000 4WD extended cab (3 door) Silverado 1500 with 5.3 V8, 6.6' bed, auto trans, towing package, and a/c. I am the original owner and the alternator has never been replaced. Thanks.
Stock is the 105
145 is stock on 05 and newer. 130 was the HD i believe but will go on without issue. It just needs a slightly longer belt i believe
I would bet it's a 105, but it should be stamped on the alternator, at least it was on my 2002.
Thanks. I couldn't find any marking> Maybe it is underneath the alt, but I haven't taken it off. As you said it is probably a 105 amp. Worst case I'll just have to return the parts. Thanks again.
Thanks. Already received the kit, but haven't installed it yet. I'll squawk back if it doesn't fit due to the alternator.
