Bummer
WLC
Shut the door on my truck today and after walking a short distance away hit the lock twice on the remote. I noticed the horn did not blow so I went back to check why not.What I found was the door was only partly closed and realized that was the reason for the horn not beeping but opened the door to investigate. Now the bummer part. The seatbelt did not retract fully and the buckle wedged between the door and plastic trim around the seat bottom.Result is busted trim.Double bummer! Everyone check your seatbelt before shutting door!
While OCD can be debilitating in some cases, in others it can be handy. I can't stand for my belt to even be twisted after I release it.
I better go out and check mine. Yesterday my horn did not work for the first time.
Around here, a non-working horn means a failed safety inspection. On a lot of cars (Cruze, for example), the horn relay is soldered down and more expensive than it should be to replace.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,119 Guests (See full list)
