Grille insert
I've been trying to find a high country grille insert to replace my LTZ honey comb grille. Anyone have a link to purchase one online?
I have purchased two different grille inserts in the past. It seems eBay is the best place to look.
Edit: Mine didn't replace anything but bolted onto (through) the stock grille. Cheap and easy. Also, not very high quality.
