Rancho Shocks
$145.00
I replaced the shocks on my Sierra, so for sale the Ranchos go. They have around 5000 miles on them. The came off a 2015 Sierra.
Shipping will be the actual cost. You can go to Fedex.com and get shipping cost. Box size is 21x14x8 weight 28 pounds.
I'm located in zip code 19348
Josh
