Iridium vs Platinum plugs in '01 Sierra 5.3L
Will I lose performance going with the platinum vs. iridium? At double the price I don't remember buying the iridium shortly after I bought the truck but may have. I get good gas mileage on hwy. Auto store said I would sacrifice performance using platinum. I don't remember iridium being OEM....?
320K, 2001 Sierra SL 5.3L 8' bed.
Trying to save a buck, but not at the cost of having my truck run less good than it does now... I love this engine!
Thanks.
Won't lose any performance, imo. A 320k engine doesn't need a 100k plug installed
Thanks, txab. That's exactly what I was thinking. Young girl at the auto store was freaking out. I don't think I used Iridium before and what I have in there have over 100k on them. Good power, mpg, and overall behavior now.
I always understood the differences only affect life of the plug mostly. The price is double+ for the iridium.
I been living in the Permian Basin last 4 years... you?
Platinum was the OEM plug. Iridium came later. I don't think there's any supposed performance gain - the iridium plugs are just supposed to be harder and longer-lasting.
My original platinum plugs in my '01 5.3 Burb were changed out at 100k. The engine was running fine, but the manual said replace the plugs, so I did. They looked pretty good - a little electrode wear, but that's about it. I put in iridium plugs because they were "new and cool."
Well, come about 185k miles, the engine really started running like crap. Hard to start, rough idle, etc. I pulled the allegedly harder and longer-lasting iridium plugs, and they were toast - severe electrode erosion. I was amazed the engine was still running at all. Should've taken a few pics. I put platinums back in the truck.
No more iridium plugs in my trucks.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
