Click/Pop Sound
Txnolebd
First I wanna say I have searched the forums for information on this and while I think some have experienced the same sound I'm curious if anybody has had the problem resolved. The issue is when at a stop and pressing the go pedal I hear a single click or pop. I don't notice it all the time but do notice it most during the first 5 min or so after starting the truck. I am curious if anybody that has experienced this has found a solution they would be willing to share. Truck seems to run fine it's just very annoying.
The click is the transmission make sure they have done all the updates and if so
tell them you want a new transmission I had mine replaced at 3k miles and so have others on this form look in the topic 6.2 with 8 speed
I'm gonna take it in this week. Did yours click after the truck was warmed up? I was holding since my truck wasn't built until late June it would have all the updates.
Can't remember if it done it cold but it was almost every time I took off
In heavy stop and go traffic it was always shifting hard and very noisy but other then that no
