Love my 6.2L Sierra!
SierraRx6.2
I'm brand new to this forum, thought I'd introduce my ride. Bought my 2010 GMC Sierra brand new off the lot with 19 miles on it (17 was my own doing test driving it). It's a 6.2L 4x4 extended cab that I've leveled out with a 2" front level kit, 285-50r20 Toyo AT II Extreme tires wrapped around 20" Fuel Anza wheels. The only other modification from stock has been the billet grille insert. I'm joining this forum to look into other ways to modify or enhance my truck and had some questions about LED lighting. I have the main billet grille and the lower grille in billet as well, but was thinking of installing an LED bar where the lower grille insert is currently located. I don't know much about it as of yet, but just getting started on my research if anyone has suggestions for websites or companies that are good and reputable for quality products that will fit nicely. Also would like to update the dome lights in cab as well as exchange headlamp bulbs with LED if possible to get a standardized look to all the lighting on my truck. Looking forward to hearing what you have to say!
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
