Anyone running lrg wheels?
Ryan698
Curious if anyone is running lrg wheels and what they think of them would like to see some pictures of anyone on 20s with lower offsets? Something that fits nice on stock fenders
Sent from my SM-G900W8 using Tapatalk
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
