Denali Driving Lights
New in Gm box driving lamps assemblys "FOG LAMPS". Never installed. Cost over $200 I will let them go for $100 with shipping in the US
Are these the headlights or Parking lights/ Blinkers? Thanks in advance.
These are the complete fog lamps with mounting brackets and bulbs.Still in the box. How about $75 shipped here in the US? This is for both right and left.
