Ok, explain how you get the little rubber cap seated over the caliper slide pi so on a 2012? I had a couple pop out and you can imagine the results a year later.
What's the trick? Or are mine swelled?
Sent from my SM-T350 using Tapatalk
Mine must be swelled...like pushing five pounds of dirt into a two pound bag. I've fought with everyone of them...at least they can be replaced without pulling the wheel.
I ordered several sets, different brands; to set see if either swells worse than the other. These are definitely too big to fit back into the grooves.
I'm thinking I might drill the caliper and install a zerk on each slide pin...just because I can.
You can see how much that plug swelled in the photo...all eight were that way.
I ordered AC Delco and Raybestos thinking I would get two different seals...nope, both made in China and both have the same bag (with the same part number on it) in a different box; they are the same seals!
So I wasn't losing my mind...
Sent from my SAMSUNG-SM-G730A using Tapatalk
    ottogriffin
    ottogriffin
  • Who's Online   2 Members, 0 Anonymous, 508 Guests (See full list)
