2500 HD with 35" tires
Troy01
I just bought a new 2015 2500HD. I would like to put 35" tires on it. Does anyone know if they will fit with a 3" torsion bar lift in the front and a 1 1/2" blocks in the back ? And are there any issues with the torsion bar lifts ?
I have the 2014 classic version. I wouldn't suggest a 3 inch torsion bar lift out of the gate because it is essentially doing the same thing that you can do with factory keys. I have 33s on mine with no leveling kit and they don't scrub. The 2015s have a little larger fender well. You should be able to run a 295/60-20 without too much scrub on factory keys adjusted up some. The width of the 35-12.50 will be what would rub on stock wheels. Try it, worst case you can buy a leveling kit after. If they work you likely will want the Bilstein 5100 longer shocks.
Sent from my SM-N910V using Tapatalk
What size offset do you have on your wheels ? I like a deeper dish wheel and I was afraid of rubbing with those. But it should like a good idea to try that first
    timcpeters
    timcpeters
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
