How to??
CruseMissle
Does anyone have a good link or know how to get the dash speakers out the 14/15 Sierra and Silverados. I googled searched it and I found a link that won't let me look at the pictures even after making a login for that site.
It's easier than it looks. A small part of the dash comes off and they lift right out.
Finally got that link to work. Had a rattle show up yesterday and took a look today. The dash speaker was blown. So I'm replacing those two now. Thanks for the reply
