Struggled getting the bumper off
Ryan698
Well apperently where I had issues with the clips there you can loosen some bolts from the back worst case senerio and makes the clips easier to pop out
Sent from my SM-G900W8 using Tapatalk
Thanks for the input guys was able to get it all off the other day was not to bad once I got in there again
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 846 Guests (See full list)
