DARWIN AWARD WINNER
bcfitzsimons
Just thought everyone might like to read this-
Finally, Nominee No. 9, The Winner!!!:
>[Arkansas Democrat Gazette]: Two local men were injured when their pickup
>truck left the road and struck a tree near Cotton Patch on State Highway 38
>early Monday.  Woodruff County deputy Dovey Snyder reported the accident
>shortly after midnight Monday. Thurston Poole, 33, of Des Arc and Billy Ray
>Wallis, 38, of Little Rock were returning to Des Arc after a frog gigging
>trip.
>On an overcast Sunday night, Poole's pickup truck headlights malfunctioned.
>The two men concluded that the headlight fuse on the older model truck had
>burned out. As a replacement fuse was not available, Wallis noticed that
>the
>.22 caliber bullet from his pistol fit perfectly into the fuse box next to
>the steering wheel column. Upon inserting the bullet the headlights again
>began to operate properly and the two men proceeded on eastbound toward the
>White River Bridge. After traveling approximately twenty miles and just
>before crossing the river, the bullet apparently overheated, discharged and
>struck Poole in the right testicle. The vehicle swerved sharply right,
>exiting the pavement and striking a tree. Poole suffered only minor cuts
>and
>abrasions from the accident, but will require surgery to repair the
>testicle. Wallis sustained a broken clavicle and was treated and released.
>"Thank God we weren't on that bridge when Thurston shot his b**** off or we
>might both be dead" stated Wallis. "I've been a trooper for ten years in
>this part of the world, but this is a first for me.  I can't believe that
>those two would admit how this accident happened," said Snyder. Upon being
>notified of the wreck, Lavinia (Poole's wife) asked how many frogs the boys
>had caught and did anyone get them from the truck.
Thank God-at least they can still have the frogs for dinner.
Fitz.
