Rough Country LED Light Bars....
Anyone purchase these light bars yet?
My Buddy has a 50" across the roof of his F-150. Seems like decent build quality, no issues to report after 6 months of use.
IMHO I don't see any difference between that or the other cheaper models.
  • 2 months later...
I recently purchased 2 led pods from touch country for $90. They seem to be very bright as backup lights. My buddy has Rigid Dully on his jeep and they are brighter, but for the price to brightness difference i would go with rough country. I am about to put a 30'' Rough country behind the grill so I will let you all know how it works compared to a cheap Chinese one i just took out.
