Kazaa Lite
Elwood
Anybody else that uss Kazaa Lite having problems lately?  I haven't been able to get anyhting for a week or more.  It finds results when I search, but everything I try to download say I need more sources, no matter what it is or how many users have the file.  Just wondering if the problem was on my network here or if it's Kazaa.
Ok.  Thanks.  It's probably our network here, everytime I get a program I like to download stuff they firewall it.  I'll look into it.  Thanks.
