Cabella's Tactical Seat Cover
Checking to see if anyone owns this paticular seat cover or has seen one in person for 2015 silverado ltz crew. I've read all the reviews for every type of seat cover brand imagnable and i really like the look of these cabela's
Curious about the quality of materail and fit considering front and back each cost $299 and with the "tactical" extras $399.
Thanks.
http://www.cabelas.com/product/Cabelas-Tactical-Seat-Cover-Without-Pockets-by-Ruff-Tuff/1303616.uts
good friend has them-they are exactly what you'd imagine: extremely nice and durable, and extremely expensive......
They are made by Cover King.
I have had them since my 2012 was 6 months old. They hold up well, except where they are seamed, where they fuzz up...they don't fray, just get fuzz. My biggest complaint is the driver's seat bottom tends to slide forward.
As far as being durable, I have sat down with a screw driver in my rear pocket without as much as a snag...more than once. They clean very well, and if needed, throw them in the washing machine. If they had a waterproof and/or sticky coating on the back, they would be perfect.
Sent from my SM-T350 using Tapatalk
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
