Steering wheel clicking no lift
SAKO79
Please only post on this thread if you're having the steering wheel clicking noise and you have no lift kit or leveling kit installed I would like to find out if people are only having this issue with a lift kit or leveling kit
I just had this happen overnight to my pickup (stock). Whenever I would turn the wheel at all it would click. Took it to the dealer and they replaced some U joint in the steering shaft. I dont know all the details on what they did, but it was all covered under warranty.
I just had this happen overnight to my pickup (stock). Whenever I would turn the wheel at all it would click. Took it to the dealer and they replaced some U joint in the steering shaft. I dont know all the details on what they did, but it was all covered under warranty.[/quote
Can you post the service record from the dealership
The description on my receipt says "Found U Joint in Upper Intermediate Shaft Binding. Replaced Intermediate Shaft after Removing Adj. Pedals for Access then Reassembled and Tested OK". The part number used to replace is 23167615 (Shaft 6.526)
Did your truck do it all the time or only after you drove it awhile?
It just started one night out of the blue. It clicked when I drove it that night, then the next morning when it was colder out the clicking was very soft. After driving the pickup for about a half hour the clicking was back to loud and happening with every turn of the wheel. I got it to the shop that morning.
How long has it been since you had it fixed? How many miles have you out on the new part?
Thanks
Been a week since it was fixed, and probably 300 miles and no issues. It was a really random problem that just appeared out of the blue one night that I had fixed the following day.
The clicking noise started again so I took it back to the dealership they put it up on the hoist and followed where it was coming from and it's coming from inside the rack the passenger side tie rod is actually moving up and down the technician told me GMs if there is any modification to the suspension so they are blaming it on a lift kit.
There are a technical service bulletin on it the first thing they must do is change out the bushings at the end of the rock where the tie rods go in and if it still does it after they replace it and without the tie rod hooked up to the wheels then they'll replace the rack
are they charging you for this?
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
