What deodorant do you use?
General Lee 01
29 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
General, this is getting sad.  You have now come pretty dang close to using up all possible poll questions.
Me, I don't care what kind I use as long as it isn't old spice.
What's up with this thread???  Are you getting a little "stinky" and thinking  that you'd like some advice before you switch?
Shane, Youda man. I'm lmao.
I guess I am really pathetic. I have to use Drysol because I sweat really bad. I try to only use it once a week and then use whatever I happen to pick up at the store that smells decent. Let me go check......Speed Stick Cyclone. If I don't use the Drysol, I ruin way too many shirts. Trust me, it sucks.  :lookaround:
I have used Arrid XXDry alot in the past and like it.
