Wiring a small powered sub
I have a 2015 Silverado Ltz Bench seat with Bose system and no sub. Adding a little more bass and have everything hooked up (power, turn off, ground) but needing to find signal. Everything I have seen on threads show various color wires. any help on what color wires and where to access them for this model? Attached is pic behind my link screen.
Behind the mylink screen there are two harnesses up top coming from radio, green and gray. Can I tap in from here?
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,376 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
