LS shops around NW ohio?
cochran223
wondering if anyone has had good luck or positive experiences with any shops in northwest ohio specializing in LS motors?id like to get a new camshaft and also the spring kit for my 6.0 2005 2500hd but would prefer to go somewhere that has done LS work before. any info comments concerns appreciated, thanks.
Indiana is a bit out of my jurisdiction but I have been having a hell of a time finding something around Toledo. Thanks!
  • 1 month later...
Did you end up finding anything? I am in the toledo area and have been contemplating doing a gear swap and tune. I was hoping to find someone locally but haven't had much luck. I called diversified and they were supposed to call me back. I never heard anything though
  • 2 months later...
Little late, but what I was told when I called Diversified they are generally around $1000 per axle on gear swaps. Was quoted $1500 by Ring & Pinion Shop of Oakland in Waterford, MI. It's a bit further away, but figure 40 years in the business and $500 less and still using quality parts, they are worth giving them the business. Hate to say it, but seems hard to get a straight answer from Diversified. Was the second time I asked for a quote and the first time I stopped in and asked for a quote on lift and install. I was given a price, but told to call back in two days, so they could verify the amount.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
