First Look at SRX
Greg
As we came out of Outback tonight, a Caddy SRX with an "M" plate came in.  The GM guy was cool, letting us take a quick look inside.  The vehicle is bigger than I thought it would be, especially since it's built on the same platform as the CTS.  We didn't get a good look at the front, but the rear quarter looks kinda minivan-ish per my my wife.  She decided she likes my Avalanche better.  (She's not one to comment positively about my trucks, so I was happy.)  The AWD, Northstar unit did have some nice, wide rubber on it.  And the GM guy thanked us for buying GM as we got in the vette.
