GM-Nagivations.com Bypass Module
CJCameron
Hello everyone. I was wondering if anyone has purchased the Mobile Video Integrations (MVI) Vehicle in motion bypass module? I have seen a video of it but I have not been able to see if anyone has purchased it and their feedback on it or problems with the system. I have a 15' 1500 Silverado and would like to get the Vehicle in motion bypass mainly because it's cheaper than the RSE monitor for my kids to watch shows on long trips. Thanks.
http://gm-navigation.com/added-accessories/video-options/2013-2015-gm-video-in-motion-and-navigation-unlock-89.html
