No power in 6.0!
031500hd
I have a 03 1500 HD Crew W/ quadrasteer, when I twist her tail at about 20-25 mph it kicks down and she wants to go but its like something is holding her back. I've been driving for 24 yrs I very aware of the way vehicles act, there is definatly something wrong.
Any body have the same problem and hopefuly an answer!
Probably a bad sensor keeping the timing retarded.  The dealers diagnostic tools should pick it right off if it's a solid failure.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
