2015 Sierra Exhaust Rattle on MBRP
I have a 2015 sierra with 4000 miles. I installed an mbrp catback at about 500 miles. Recently I have noticed that when I step on the gas to leave a stop sign or light the exhaust has a noise that sounds with marbles in a can. Any suggestions?
When I removed the factory exhaust that got rid of the flapper valve issue right?
Sent from my SAMSUNG-SM-G925A using Tapatalk
Your MBRP being a catback, you obviously took the factor one off so unless that MBRP has a flapper valve for some reason, you would have no flapper issue. Did you purchase from a shop in town and they installed it? Did you order online and install yourself?
Hmm...I guess I'd check and make sure all the clamps are tight, maybe take a rubber mallet and tap on the muffler see if there is anything loose inside. Interesting that its under load when you hear it.
I had exhaust rattle on mine. check the flex part of the exhaust. Mine was touching the cross member on the front part
    Tbhats2130
    Tbhats2130
  • Who's Online   1 Member, 0 Anonymous, 1,977 Guests (See full list)
