Adding Nav?
Is it possible to load Navigation to the truck if you didn't get it pre-installed? I have the 2015 Z71 LT
No, as long as you already have the IO5 radio (8 inch screen without nav) all they do is add a GPS antenna and a flashed module
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
