Texas Edition??
todd11231
I've seen the ad on TV about the silverado, but haven't seen one or know what makes them special. We have 3 texas edition f-150s at work that have a bunch of chrome junk and a Kenwood CD MP3 player from the factory. :smash:
Usually,the Texas Edition is somewhat of a base model truck with a few standard creature comfort options plus the deluxe appearance package like on the LS Silverado.
Ford seems to have taken it a few steps further with a unique dash bezel,stereo and aluminum wheels.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
