Caddy walking. Please help.
Just got new tire and alignment this morning. and my numbers are almost identical to yours. My thrust angle was out more before and I had no abnormal tire wear on the old tires except the right front but that tire was toed way in (0.30°), as you can see buy the alignment sheet below. I really wouldn't sweat it unless you unusual tire wear.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
