Xenondepot.com 15% off and free shipping today
SC_Mike
Does anyone know if the xenon depot LED are DOT approved? Perhaps it doesn't matter because I am only changing bulbs, and not reflector or projector
Sent from my Nexus 6P using Tapatalk
I bought the fogs and headlights. Hopefully this works out well. The fogs were my biggest issue as I felt I never got enough light. Let's see how this ends up.
Sent from my SM-N900V using Tapatalk
I got my product today and trying to install on my Silverado. Question. When I install the LEDs in the low beam projector housing do I refuse the larger cap that covered the entire bulb? It seems to not want to fit but wanted to check
I have the H/lamp and fog bulbs in 2015 Sierra. The H/lamps are a little better than stock but not much. However when the h/lamps and fogs are both on, it is better than stock. Overall I like them as they are a little brighter and much better color.
So tempted, how is the install with these in the sierra? The only thing i'm worried about is the fact with the adapters and if installing it means shoving all of it into the stock housing and having the dust cap fit back into place. One reviewer commented about how the install process is kind of like shoving 10# in a 5# bag. That made me not order these yesterday.
They were not that hard to put inside the housing and putting the dust cap back on. I had no issues. I didn't get the canbus.
  • 1 month later...
I completed the install of the headlights and fogs about a month ago. The hardest part of the install was pulling the OEM bulbs from the housing. It's such a tight space, that my arm could not fit well. Im not a big guy either (5'11, 185). So far everything seems to be holding up well. Im pleased with the light output, and they look super cool.
Any pictures? How's the cutoff?
i dont have any pics on hand, i'll try and take some in the next few days.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
