16 1500 tow mirrors
Cfitz89
Hey guys, I'm looking for tow mirrors for my 16. Will the 14,15 mirrors fit on the 16?
Don't forget the you will need new door harnesses for the LED reverse lights and marker lights to work properly. Or you could go the route of others and wire those functions yourself.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,344 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
