Newbie from NE says "cool website!"
RoadrunnerRod
Hello everyone! Been checking out the site for a month or so, lot's of useful info! Anybody else here from NE?  :cheers:  Hope to get more info to use on my 99 Z71 ext. cab. Never thought such a heavy vehicle could haul so much ass! :)  :chevy:
Thanks for all the welcomes, everybody! There are a lot of nice looking (and fast!) trucks on this site! :wtf:  BellevueSilvy- I'm currently a Lincoln resident, but also lived in Hastings and Columbus. Maybe someday I'll be able to escape the state, but it could be worse. Could be living in Iraq, or something! :crackup:  :thumb:
Welcome to the site.  I am in Nevada, but I have tons of family back in Nebraska.  They are in and around the Central City area.  I will be out there in another month for vacation :thumb:
