Creaking when off-road
I hardly ever take my 4x4 off road, but lately when I have been off road, there is tremendous creaking, VERY noisey.  I asked an auto shop about this, and they said there isn't many points available for lubrication, and that it comes from the factory that way and not much can be done about it.
Is this true???  What can I do about this unbearable creaking?
Thanks!
Where's the creaking coming from?  we need details?  Do you have a body lift or is it stock?  Maybe a chassis lubrication would prevent this.  There are only 11 grease zerks on the NBS Z71s, not sure how many you have, but i REALLY doubt this is the cause of the creaking.
could be the bushings.  I forget the company but they make suspension replacement parts (energy suspensions???).  They have not yet come out with the newer style trucks yet but i was told this summer they are.  This should help with the creaking
Yeah, everything is stock on this vehicle.  It isn't the Z-71 package, but the more comfort package.  I'm not sure where the creaking is coming from but it only happens when there is there is a lot of up and down type movement of the wheels, or compression of the suspension/shocks, even when rolling slow thru something.  I hope that is a good description.
kristi
It could also be the door moldings as the doors rub as the body flexes.  This can be cured by putting some silicon grease on the moldings.
...I'm not sure where the creaking is coming from but it only happens when there is there is a lot of up and down type movement of the wheels
I get this after going through rocky, red-clay mud roads. Rocks and junk get trapped in any area that can hold them and rub against "stuff".  Then my leaf springs get the same stuff on them.
In short, I have to high pressure wash the underside of my truck after encountering such lovely roads and until I encounter them again, I have that smooth, quiet, caddylacky ride.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,208 Guests (See full list)
