Tow ratings
FishAr
Yes, I really need to go to the scale.
I put the truck in as 5400 and then added 950 pounds for people, dog, shell, golf clubs and other stuff in the back.
I honestly don't even know what the truck weighed when I bought it, I think I got 5400 from some internet site.
I'm not sure how the weights differ between a crew cab short bed and double cab regular bed (your truck) but, I hauled something to a land fill and my truck weighed 5880 lbs with me (190 lbs) and normal stuff that I carry. I don't know if that helps you or not.
  • 1 month later...
I kind of forgot I posted this thread. Not taking trailer to Florida until December when my one year lease starts.
I pulled it home and parked it though. Around 25 miles on the route I took, there were shorter routes but it's a long trailer and I didn't want to go through town. WDH with 1200 pound bars and double sway bars. Pulled it at 60-65 mph.
It pulled great, just as good as the smaller 29 footer I use for work and camping local. I took the 29 footer, the one in my signature, down to Florida last winter and back. Probably 2500 miles total. It wasn't a battle. (that's 29 ft tip to tip, box is around 25 ft or a little more)
5770 on the smaller trailer sticker for dry weight. Wife had it loaded to the hilt. I also had a loaded cooler, golf clubs, dog kennel, 5-6x6 18 inches long for the stabilizer jacks, 3 ton floor jack, tool box in the back and 450 pounds of me, wife and dog in the front. The engine brake on the 2015 5.3 is very handy, came in real handy on Monteagle Mountain.
Still yet I love for a 2500HD. Matter of fact is I'm looking at 3500hd duramaxes instead just in case I decide to get a fiver in the future. Haven't had my current truck long enough to come out on a trade yet though.
Thanks for the update. Glad it pulled so well. That's great to know it has a lot of reserve in it based on my rig. These are great trucks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
