305's on a lowered truck??
Hi Folks,
I am trying to find the right tires for my 2015 All Terrain.
It is lowered 2/3. I don't want A/T type tires, more like Toyo Proxes STii
These are the wheels Foose 20-9.5- + 30 offset.
http://www.mhtwheels.com/switch-f158-w-6089.htm
I believe the outer lip of the new rim will be slightly in from stock.
I am hoping to use Toyo ST'S 305-50-20 which are 32" X 12.2. stock tires are 275-55-20 31.8x 10.9.
Will they fit the front without too much rubbing, if any,
and will they have the right stance?
If not any suggestions??
I ran 305/40/22 when I had my truck at a 5/7 drop no issues
Sent from my SM-G920V using Tapatalk
Were they on a 2014-2016 Truck.
That's pretty close in size,
31.7 inch od x 12.2 compared to 32 x 12.2 for the 305-50-20
Yea I have a 2014 you should be fine even ran 295/30/24 on it at a 2/4 drop no issue
That's with 24s
That's with 24s
Wow, nice truck and setup and thanx for the info.
I think the 305 will work then.
Do you recall the offset on your wheels?
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 806 Guests (See full list)
