Upgraded rear camera
When I purchased my 2014 Sierra I quickly noticed the very blurry and poor quality image from the back up camera. The old ladies '13 cruze was MUCH better. I assumed it was the 5 gallon bucket of wax they put on every inch of the truck but after striping it clean it still has blurry edges which really sucks at night. Are there upgrades to the camera?
I would try cleaning it really good. My camera is crystal clear. It got a little hazy when the dressing from my handle ran after some rain, but a quick cleaning helped that.
There are no upgraded cameras available. I am in the exact same situation (even with a 2013 Cruze!) and have talked to all the OEM suppliers. Nobody offers anything with better resolution :nonod:
That sucks because the camera is pretty bad. My mom's 2011 altima is crystal clear as in you could read from it.
Sent from my SM-N900V using Tapatalk
Maybe you need to take it in to have it looked at , mine is crystal clear
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 812 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
