Suburban Cooling Fan
Hello:
I have a 2002 K2500 Suburban with the 8.1L engine.
The last month or so I have noticed that the temp gauge shows the engine running hotter when in traffic or idling. I thought maybe the thermostat was going bad, but it didn't overheat so I was still trying to figure out what it was.
I took the truck for the yearly safety inspection and a wheel alignment to my mechanic. On the receipt they also note any trouble spots they notice as a heads-up. On my receipt it said "cooling fan hitting shroud". I looked under the hood, spun the fan by hand, and it does hit the shroud at the bottom.
The shroud seems very stiff and well anchored, so it doesn't seem like the shroud has moved. The only thing I can think of is that the motor mounts are worn and the engine has dropped slightly. The sub has about 168K miles on the original mounts.
Any thoughts?
With warmer weather coming, I need to fix this ASAP.
Thanks
Steve
  • 3 weeks later...
Do you hear a big clunk when you get on it or put it under load? Why didn't the tech look at the mounts? (that's easy $$$) Is the fan clutch in tact?
Grab the fan blades 180 degrees apart and shake it back and forth. Look for any side to side movement. If there is slop in the bearings, this could allow the fan to droop enough to hit the shroud.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
