Fuel line replacement
Anybody replace their NBS fuel lines with the GM kits? It looks like it comes as a whole assembly which would be ok if it was going down an assembly line as a bare frame, but seeing as I'm in my garage with no lift I'm thinking I need to seperate the whole unit and do them one at a time. Anyone? Any input appreciated.
Sent from my SAMSUNG-SM-G870A using Tapatalk
  • 3 weeks later...
What year truck are you doing it on? It would probably be easier with a lift at your disposal, but it could definitely be done with a set of ramps. My fuel lines are listed together on my 02. I've been thinking of getting a set of stainless fuel lines.
It's a 02.. I did them last week they were pretty easy actually. I seperated the lines then removed the front driveshaft and unbolted the abs module and they slid in with a little maneuvering. The shops quoted me 10.5 hrs labor.. it took me about three. I replaced all my brake lines with stainless a few weeks ago as well so hopefully no worries with lines for a while..
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
