Bilsteins with lift
I have a zone 6.5 on my 16 Sierra all Terrain and it rides really rough. I would like to swap the oem rancho strut for bilsteins. Would this smooth out the ride? Thanks
Sent from my E6853 using Tapatalk
The 5100 series will make it ride stiff at the max setting but its a huge improvement from the rancho suspension. You will have to get the front ones done at a shop as they will have to compress your spring and the rear are very simple to install i recommend putting a some protective coating around the shock body keeps it from rusting ect. Fyi its not a 100% level but it looks a lot better well worth doing it the right way instaed of spacers
Like I said I have the zone 6.5 inch lift so I would be swapping out the oem rancho for the bilstein on the lowest setting
