Yokohama Geolandar A/T G015
GMD's GMC
https://www.yokohamatire.com/tires/detail/geolandar_a_t_g015
I just saw that these were released and I'm sure no one has them on just yet but figured it would be worth asking about.
I have the stock SR-As on my All-Terrain and hate them but will use them up. I'll be swapping tires at some point this year and want to consider these as a replacement.
We have always had great luck with Yokos, have had 2 sets of the Geolandar H/Ts on my wifes 4-runner and they are long lasting, quiet and have great grip in dry and wet.
I want an All terrain tire as I do go off-road every once and a while when hunting or if I see a mud puddle and I want something that will handle it better than the SR-As but not be a droning mess on-road where I spend most of my time in the truck. Wet weather grip is a big deal, I don't trust the SR-As and whenever the roads are wet, I switch to Auto so I'm not spinning the rears at a stoplight.
These really look good and have a good tread pattern that would seem to meet my needs.
I hope someone out there already has a set or has some experience with any Yokohama AT tires.
Thanks!
Following. I used Geolanders on my 99 Silverado and Jeeps, and they did great, but when I got my 08 2500HD and went with Geo's.. well.. they did not hold up very well. If I see enough positive reviews I would consider trying these out.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
