Sierra 1500 towing w/o WD hitch
I've never needed a WD hitch towing car trailers over the years. My current trailer is a v-nose 24' that doesn't have space for a WD hitch. Looking at a Denali 6.2l 4X4. Will I have issues? I don't want to end up getting a different trailer to fit the truck. This is an issue with the new F150. Only a 500lb max tongue weight before a WD hitch is needed. I see the GMC has an 800lb tongue max.
Anyone dragging car trailers. I know campers are different animals because of the inability to adjust tongue weight.
I don't want to go with another 3/4 ton truck. Max trailer weight with my heaviest car is less than 7,500lbs.
Say you were at the 7500lbs (heaviest car per you with trailer is under that). GM calculations are at 10-15% trailer weight for tongue weight. If you positioned everything to fall on the 10% side of things, that would be 750lbs tongue weight, just shy of the 800lbs tongue weight carrying rating GM has. I'd say depending on the actual weight, if you can keep the tongue weight right at 10%, I'd say you'd be okay.
Is this an enclosed car trailer? I am guessing so, but not sure....
You probably can still run a wdh with it, but it is a little bit of a pain to hook up! Reese (probably other companies also) has a chain bracket the is bolted to the frame with a book on it (no snap up bracket). You will probably have to mount it up underneath on a more solid frame member and not the "outside v frame", but it should work pending your trailer. My dad had this same issue with a tongue that was to short, even after specifically asking. Issue was guy went an measure a trailer, not knowing it had the extended tongue on the trailer he measured......
Good luck!!!
The one thing to remember is most good WDH have sway control. I will tell you this makes a huge difference when you hit a chunk of steal and rip open a trailer tire.
I had a tire blow on a small hardtop 1500 lbs once years and years ago with just standard hitch and it almost pulled my 4700 lbs SUV around.
I was also a passenger when I was a teenager in a a Dodge Ram charger pulling a 26Ft boat that came right around hit the side of the truck in a bad rain storm.
One of the reasons why I always tow things the safest way possible. You can't control everything in the world!!!!!!!!!! so control what you can :)
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 286 Guests (See full list)
