Vled 4500 lumen LED pair and 3d printed dust caps
I have a set of vled 4500 lumen LED headlight bulbs. I also have 3d printed dust caps to allow for the fan. 200 shipped for both the bulbs and caps. I will upload pictures later. One bulb and ballast is used the other is new. I definitely like the instant start up and they seem to be very good quality. I only used for a few months.
I'm selling because I put my hid back in. Just prefer them more. I had one of the led quit working and got a new one through warranty replacement. I would sell just the caps. I would prefer to sell both though. The caps do make more room for the LED fans. What is the shipping zip code?
VLED lights
Here is the picture of the 3d printed caps, lights, ballasts, and harness. I realized today that I did not receive a new collar. I will be getting a new one before I ship these.
  • 4 weeks later...
Sorry I did not see this sooner. The hole with the grommet in them is 5/8". The height from where they would rotate in is 1 1/4". The grommet can be removed.
125 shipped for everything.
  • 3 weeks later...
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
