Would putting long tube headers on my truck that has (Flowmaster super 44s) make it louder and sound better or would it make it have that crackle/pop/raspy crapyy sound. If so let me know so I can save my money
It will make it much louder, and will likely induce some rasp. Changing to another muffler would help, or adding a resonator.
Sent from my SAMSUNG-SM-N910A using Tapatalk
​The main purpose of adding long tube headers SHOULD be to increase exhaust evacuation, why then would you want to add a restriction like a resonator?
​chevyboy864 if you are worried about crackle/pop/raspy drone, DO NOT INSTALL LONG TUBE HEADERS, because that is what you are going to have.
​If you do install them, make sure you open up the intake, and have your A/F ratio adjusted. For LS engines WOT should be @ 13.5:1 ratio.
I agree the main reason should be performance oriented. However, there are good gains to be had by changing to a long tube header, and then adding a resonator.
On my CTS-V I made 720rwhp with 2" primary headers and 3" corsa exhaust all the way back. The setup was insanely loud so I added a 22" magnaflow resonator to each pipe. It completely eliminated the rasp, and drastically toned down the exhaust. The car ran within one tenth of a second in the 1/4 mile. Hp different on the dyno wasn't enough to register between what most would consider day to day noise (like 5 hp...which could have been a result of heat, DA...)
No tune adjustment was needed, meaning the resonators had zero impact on AFR as measured by a tailsniffer.
So would resonators hinder performance? Yes...but is it enough to matter...on this size of a truck? Probably not.
No revs, but you should be able to hear a difference
I have Texas Speed long tubes and a Borla cat-back and its not crazy loud, but with not having cats your truck will smell like gas. People in line at Whataburger HATE me. But it does sound good! Once I do a cam it will sound even better! :nopity:
Sounds way better without the resonators, but I'm a drag race guy.
How were your times?
I agree it sounded better...but it was INSANELY loud without them.
It ran a 10.9 at 135, had lots of power but the 6 speed manual was a limiting factor.
Did 162 in the 1/2 mile
    ballencd
    ballencd
  • Who's Online   3 Members, 0 Anonymous, 446 Guests (See full list)
