Im trying to install the window trim any videos how to install
Need help was easy to remove but when installing clips don't locked
They are more then likely broken!! Look on the inside of the clip towards the door and there is where the clip is broken if its not clipping back on
I have a post-it at my desk with this clip part number written down: 11547339
How accurate are you on that with that part number? I dont believe they sell the clips individually for the molding
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
