core - shifters nv3500
barry G
just got this in the email.
A limited quantity of NV3500 shifters for GM trucks are now available for order on the website:
http://core-shifters.com/collections/shifters-for-silverado
Please make sure to select the correct model year / platform and if trans is not original, receptacle height measurement is suggested prior to order as discussed in those listings.
Please note Dodge Ram shifters are different and still sold out at this time.
thanks,
Chris
these shifters are miraculous.
v6 or v8.
this is my truck in the video. Not sure how much work I had done yet.
the hard bounce etc.. does not do that now.
in fact, that was my first time trying to go fast...hence the camera. :)
they kept running out of them, maybe they'll hang onto them this time.
worth every penny.
for those tha do not know, the long thorw of the original has aplastic base, reacts to every engine fluid and gets squishier when you need it the most...when hauling.
been some months for this install, almost a year. the physics of it leave throttle off sounding like a blow off valve. the engine knows it is there, gaining a gear much sooner. It is as if the computer had to learn a new curve.
in fact, I must say incredible. It made a one of a kind ramp.
very fun, very rugged. I can tell what the tranny is doing at all times...and it is much cooler with the aluminum base.
edit:
seeing that old video, I can make a newer video, updated.
I would wager it gets a few giggles.
13 second quarter is hardly a guess.
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
