Service department - trying to send me back to where i purchased
so i decided to cancel and go to my regular dealership. they also have the 3rd party electronic repair company booked to check the camera. both dealers use York Electric, maybe GM Canada has a contract with them i dont know.
York Electric is an power coop in New York
http://www.yorkelectric.net/
I'm guessing you mean York Electronics. :)
http://www.yorkelec.com/
York Electronics (YEL) is the General Motors authorized Electronics Service Center in Canada for Automobile and John Deere Tractor Radios; Instrument Panel Clusters, XM Radio, On-Star and other OEM electronic accessories installed in new and pre-owned GM vehicles.
yup...thats most likely it.
all done, new software update for the camera and human interface (i noticed voice commands are a bit different)
arm rest latch fixed
undercoating recovered
intermittent starting issue was done by the foreman (who i know) no leaks, all the lines pressure test at spec so im going to run a fuel system cleaning and watch what fuel i get. generally i get esso but i try to get costco because of the price.
so ill throw in some seafoam into the fuel before my next highway drive and go from there.
i dont know why i bothered going to another dealership, sure its a hour away but piece of mind is worth it.
i had a rental car overnight but my truck was ready yesterday at about 3pm.
Glad it all worked out for you.
so ill throw in some seafoam into the fuel before my next highway drive and go from there...
Odds are they get their fuel from the same terminal or refinery. And it's likely they use the exact same additives as well. Both of those are Top Tier, but some wholesalers won't even sell anything but Top Tier equivalent anyway.
IE, if one of your areas stations is getting bad fuel, they all are.
ya the comment was make sure you use top tier fuel and i always do mostly because of the points and discounts.
we have a small station literally walking distance to my house and ive only filled up there once.
i think im just going to really give up on finding a new dealership just because its closer, stick with what works and you trust...ive been a loyal customer there since 2003 so why go elsewhere.
funny thing is after i got home i remembered i actually have a couple small jugs of the OEM GM undercoating sitting in my garage. so before winter (say october) im going to powerwash it, let it dry overnight then paint it on thick in the front end and touch up a few other spots. ill probably put my lower air dam back on for winter this year too, just to stop the salt and rocks from beating on the frame.
My dealer told me to use BP fuel in my 5.3. I was always told to stay away from BP. I always had used Marathon, but I have be getting BP now. Any thoughts?
i have no clue who supplies the ones i go to.
i know Shell has always had the best fuel for motorcycles, no ethanol...so thats what i always try to run in my bike but when theres nothing else around i just get whatever.
i think its called XTR that has been expanding a lot lately.
BP - the white gas.
After the Gulf oil spill debacle, most (all?) of our local BP stations switched to Texaco.
Yea, I had a 24' center console and it affected me but I think BP did everything corporately possible to address the accident.
Oh well. I can't buy BP anymore. Would if I could. It was my almost sole brand for years.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
