Aftermarket exhaust
Do any of the after market exhausts reroute the exhaust around the trans pan? Making it easier to drop the tyranny pan..
Its so easy to un bolt the cutback exhaust, a new light one. Couple bolts and 2 hangers. The stock exhaust has some serious WEIGHT to it.......
I run a dynomax
