Trucks! TV
TxDoc
Anybody watch Trucks! TV
I like some things and other I don't.  But, in general, I do watch and like to see some things I have never seen before.
I watch it, usually on Sunday mornings (depending on which schedule TNN is following, seems like it changes every week) as I'm gettin' ready for church.  I agree some projects are pretty cool, one off the top o' my head was the red S-10 they dropped a 350 TPI(might of been a LS1) in last year.
I watch whenever I can.
It appears that here they only show it Sunday  Night (MOnday Morning) at 1:30am.
If I miss this week's episode I'm gonna be pissed.
They're bringing back "Wicked Willys" and they'refinally gonna show the thing perform!    :withstupid:
I LOVED the Can-Back install on Project High Sierra!!
I need to get a Can-Back :withstupid:
Boti from FSC.com bought one.
Damn it looks sweet!!!
I love watching the Sunday TNN line-up.  The only thing I hate about it is the fact that they do about 4 days worth of work in about 15 minutes.  That an they have a cooler garage than me.  B@stards! :angry:
I try to watch it every once in a while, it is only on at 0130 Monday morning here usually, so I don't always remember to watch.
yeah I wish I had one of those garages too.  I'd even settle for a garage that I can actually fit my truck into, unlike the stupid garage here at home.   :withstupid:
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
